Community Member
Unistallation of CCM 4.3
Just wanted to check if the CCM needs to be reinstalled, is it possible to unistall it completely and then then install it again, rather then formatting the whole server and doing it.
If yes how?
Community Member
Re: Unistallation of CCM 4.3
I found this link which has some information you might find useful!!
http://www.spanlink.com/downloads/services/mtce/ciscocm.4-1-3-sr3a-Readme.htm
It is for 4.1 (3) but I think it should be pretty much the same...
Silver
Short answer is no. You need to blow out the whole box and reinstall everything.
i totally agree with Zin
even though there is a procedure to try uninstalling it if you're willing to do it, it's best to rebuild the server from scratch than just reinstall CUCM
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
104
