United Kingdom BRI / BT issue with incoming numbers
davieshuw
Hi all. When I do a debug isdn q931 on my CME UC520, the incoming number has the leading zero chopped off.
Can somebody else tell me if this is normal?
paolo bevilacqua
It's like that in a lot of countries. And you should see the international ones coming in without the zeros. So all you need is a simple rule to add them, and to make redial easy.
voice translation-rule 300
rule 1 // /0/ type national national
rule 2 // /00/ type international international
voice translation-profile addzero
translate calling 300
And apply the translation under interface or trunkgroup if using moret han one interface.
Note this assumes you dial-out without any prefix digit, add it if you need.
5 Replies 5
paolo bevilacqua
And just one more question.. I already have a translation profile on voice port 0/1/0 that deals with my DDI numbers. Ive noticed I can only have one translation profile there. Therefore shall i add those rules 1 and to to my exsisting profile, eg make them rules 3 and 4 of my existing translation profile?
There is no conflict. The translation-profile for DID is configured for called number translation, the one to add zeros is calling number. Two entries under same voice translation-profile.
Thanks for the nice rating and good luck!
Hi again. Ive added the following:
oice translation-rule 1
rule 1 /447/ //
rule 2 /487/ //
voice translation-rule 2 <-- new addition
voice translation-profile ADDZERO <--- new addition
translate calling 2
voice translation-profile INCOMINGDDI
translate called 1
Now. On my voice port 0/1/0 I have the following:
voice-port 0/1/0
translation-profile incoming INCOMINGDDI
compand-type a-law
cptone GB
I cant set up the translation profile on this port because when i add the new translation profile, it over writes my INCOMINGDDI .
Sorry i was being an idiot. I've added the following as suggested and it works:
translate calling 2 to my INCOMINGDDI profile and it works .... (its too early in the morning for me!)
