Community Member
United Kingdom BRI / BT issue with incoming numbers
Hi all. When I do a debug isdn q931 on my CME UC520, the incoming number has the leading zero chopped off.
Can somebody else tell me if this is normal?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: United Kingdom BRI / BT issue with incoming numbers
It's like that in a lot of countries. And you should see the international ones coming in without the zeros. So all you need is a simple rule to add them, and to make redial easy.
voice translation-rule 300
rule 1 // /0/ type national national
rule 2 // /00/ type international international
voice translation-profile addzero
translate calling 300
And apply the translation under interface or trunkgroup if using moret han one interface.
Note this assumes you dial-out without any prefix digit, add it if you need.
Community Member
And just one more question.. I already have a translation profile on voice port 0/1/0 that deals with my DDI numbers. Ive noticed I can only have one translation profile there. Therefore shall i add those rules 1 and to to my exsisting profile, eg make them rules 3 and 4 of my existing translation profile?
There is no conflict. The translation-profile for DID is configured for called number translation, the one to add zeros is calling number. Two entries under same voice translation-profile.
Thanks for the nice rating and good luck!
Community Member
Hi again. Ive added the following:
oice translation-rule 1
rule 1 /447/ //
rule 2 /487/ //
voice translation-rule 2 <-- new addition
voice translation-profile ADDZERO <--- new addition
translate calling 2
voice translation-profile INCOMINGDDI
translate called 1
Now. On my voice port 0/1/0 I have the following:
voice-port 0/1/0
translation-profile incoming INCOMINGDDI
compand-type a-law
cptone GB
I cant set up the translation profile on this port because when i add the new translation profile, it over writes my INCOMINGDDI .
Community Member
Sorry i was being an idiot. I've added the following as suggested and it works:
translate calling 2 to my INCOMINGDDI profile and it works .... (its too early in the morning for me!)
137
