Unity 4.0, extension will leave a voice mail and the VM isn't received by the end user
internal extension 0934 leave a voice mail and the voice mail isn't landing in the mailbox or on the phone of the end user, the extension recives voicemail fine.
thanks
hasrat
1 ACCEPTED SOLUTION
Re: Unity 4.0, extension will leave a voice mail and the VM isn'
Start by checking in the ADUC the user has the "allow inheritable permissions to propagate..." and run the PW.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Hi Java,
Thank you for the reply can you please explain "run the PW" and HTH.
thanks
hasrat
Permissions Wizard - rerun the Permissions Wizard.  You can run in report mode and see if you get errors.  If so, you'll need to rerun it to set permissions correctly.  If you continue to have issues after doing so, it's likely that these users are members of AD protected groups (Admins, Exchange Admins, Print Operators, etc).
Hailey
Please rate helpful posts!
Hi Java,
allowed inheritable permissions in ADU and it is working, thank you for the advise.
I also appreciate David explaining the process.
PS: I found the answer to my  HTH question
hasrat
200
