Community Member
Unity 4.1.3 Patching and Virus protection
Where can I find the approved Cisco Microsoft security update/patching. Also, what is Cisco policy and recommendation for Virus protection.
VIP Purple
Re: Unity 4.1.3 Patching and Virus protection
You can find a list of approved updates/patches here:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/osbios.htm
They can be downloaded here:
http://www.cisco.com/cgi-bin/tablebuild.pl/cmva-3des
A list of supported antivirus software can be found here:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/prod_bulletin0900aecd800f8572.html
Hope this helps. If so, please rate the post.
Brandon
Community Member
thanks Brandon
Community Member
Is there a specific or another link for Unity 4.1.3 patching and Virus protection
VIP Purple
Not to my knowledge, but as mentioned in the link, Cisco CallManager 3.2(x) and later" includes 3.3(x), 4.0(x), 4.1(x), etc.
Brandon
Community Member
the first link "http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/osbios.htm " does not support unity, is there a link for that
VIP Purple
Unity is now updated with the Unity Server Updates Wizard which can be downloaded here:
http://www.cisco.com/cgi-bin/tablebuild.pl/unity_msft_updates
This wizard will install the approved OS, SQL, Exchange updates for Unity as well as the CSA agent.
Brandon
Community Member
thanks
116
