Unity 4.1 probelm
I have a problem with my Unity 4.1
And I create new Subscriber I'm getting error message:
Error: The Subscriber template's string or the Subscriber extensiondid not fit into the dialing rules.
Also and I try to update for user under Call Transfer the "Yes, ring subscriber's extension" I'm getting error:
Extension does not fit the dialing rulesor your dialing permissions.
I have users already configure calling transfer and working with out any problem
1 REPLY
Re: Unity 4.1 probelm
It is quite possible that some one tampered with the restriction tables. Set then correctly by using the following document:
http://cisco.com/en/US/docs/voice_ip_comm/unity/402/administration/guide/ex/SAG_0240.html
Rate this post if helpfull.
92
