Community Member
Unity 4 2 help required
we are using unity 4.2 with call manager 4.2 integration has been done but as soon as we make a call to a subscribers phone
I hear a silence instead of any greeting message I have tried several times and checked each option but not able to get whats wrong I can not hear a singly greeting message any sort of help will be high appreciated.
Re: Unity 4 2 help required
have you verified there are no routing issues that could case the RTP not to reach the phone?
what codec are the prompts?
what codec are you telling the phone to use when calling unity?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Also please check the TSP version if its compatible with the Callmanager version.
Community Member
The TSP version that i see in MY Unity 8.1(2). How do I verify that its compatible with my call manager Version 4.2 (3)sr3.
I have also verified that there are not any routing issues since my call manager and unity are on the same LAN and also plz guide me how to verify what codec prompts are?
I really appreciate what u guys are doing
Thanks alot
Community Member
Thanks alot
Community Member
and also i found a avskinny file version 1.2.0.33 having description Cisco Unity-CM TSP, which found in C:\\windows\system32. can you guide me what TSP version is required and where to verify it.
the routing between the CUCM and Unity does not matter, what matters is between the Phone and unity. the RTP stream does not goes thru the CUCM server but between endpoint
SCCP Compatibility Matrix: Cisco Unity, the Cisco Unity-CM TSP, Cisco Unified CM, and Cisco Unified CM Express
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html
javalenc
java
Community Member
yes the TSP version is fine as i have checked the compatibility matrix, now how to further troubleshoot??
113
