08-27-2008 11:09 AM - edited 03-15-2019 12:52 PM
installing unity 4.2. (Off box UM)at the point of running message store config wizard, lets me select my mailbox location, then goes straight back to initial "run message store wizard". Anyone seen that
08-27-2008 11:33 AM
Is this part of a Unity upgrade? I have seen this when there is unity_
08-29-2008 07:52 AM
I have also seen the problem when you have multiple excgange servers / mailbox stores. You need to select the store where you Unity system account exists.
08-29-2008 07:59 AM
Thanks for your input. The first responder was correct. This was an re-install from a retired unity 4x server. I had to have AD guys delete unity_server name and mailbox, and also, had to elevate AD rights to the Unity/Locations OU.
08-29-2008 08:01 AM
This is most likely a problem with the Unity_
