Unity 4.2 Long silence before record beep
After you hear the system message "record your meassage at the tone" you wait like 30 seconds before hearing the beep.
1 REPLY
Bronze
Re: Unity 4.2 Long silence before record beep
As a workaround Disable the Message Monitor feature if it is enabled.
Check this bug for more details::CSCsd63459
103
