Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Unity 4 and CUCM 6.1
Hi Guys
Pls post for me the installation and configuration guide for UNITY 4 along with the steps from Call mananger side
also am looking for the configuration guide for Call manager 6.1
Re: Unity 4 and CUCM 6.1
Really?  The search engine on cisco.com is annoying at times but for things like this, it is pretty reliable/quick.
Go to www.cisco.com
Search for Unity 4 installation guide and go to the first link.  Which should be:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_installation_guides_list.html
You will find a ton of guides in this section of cisco.com.
Now, go back to the cisco home page (or any page that has the search bar) and search for the phrase CallManager maintain and operate. Again, use the first link that is provided, which should be:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
Another nice add to the Cisco site is under support.  When you hover on the support link or you click on support, there will be a search box like so:
In this search box if you put any product name (e.g. Unity, Unity Connection, Communications Manager, etc.) the search tool will give you options for products that match your search string.  Then you can go directly to the documentation page for the product you specify.  Release notes, end user guides, design guides, configuration guides, install guides, etc., etc.  are all at your finger tips.
So, search engines are a good thing.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hall of Fame Super Red
Hi There,
Here are the related guides;
Cisco Unified Communications Manager 6.x SCCP Integration Guide for Cisco Unity 4.0
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/401/integration/guide/cu4xintskinnycucm6x.html
Cisco Unified Communications Manager Documentation Guide for Release 6.1(3)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/docguide/6_1_3/dg613.html
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Many thanks Rob and william
147
