unity 4.x questions
Q1) When sending broadcast messages the MWI does not lit is this normal
Q2) With Unity notification, i can reach the state where unity calls the mobile but i cannot enter any dtmf, do i need to create a dial-peer and what it should look like?
Good day
2 ACCEPTED SOLUTIONS
Re: unity 4.x questions
1 that is WAD
Cisco Unity Conversation: Subscribers Can Receive System Broadcast Messages
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/405/release/notes/cu405rn.html#wp423116
•System broadcast messages do not light message waiting indicators (MWIs) on subscriber phones, nor do they cause distinctive dial tones to notify subscribers of a new message when they pick up their desk phone receiver. System broadcast messages also do not trigger message notifications for alternative devices, such as a pager or another phone.
If using H323 you should already have them in place, otherwise you wouldn't be able to reach the mobile
dial-peer voice 1 pots
incoming called-number .
dtmf-relay h245-alphanumeric
dial-peer voice 2 voip
destination-pattern 9T
the rest of the config for the dial-peers depends on the ports, codecs, etc
javalenc
java
if this helps, please rate
www.cisco.com/go/pdi
Hall of Fame Super Red
Hi Wissam,
For question #1;
Broadcast Messages do not light MWI's. You can setup a Public Distribution List to accomplish this and Light MWI's;
From Unity Master Jeff Lindborg;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dd8ad43
For question #2;
Cisco Unity with CallManager Problem with DTMF
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a0080094607.shtml
Hope this helps!
Rob
EDIT: Jaime, you are too fast for my lame-o typing skills :)
1 that is WAD
javalenc
java
Hi Wissam,
For question #1;
For question #2;
Hope this helps!
Rob
not at all Rob, i just got lucky and was looking at the post at the right time, glad we both got 5s for our responses and both solved the issue.
regards =D
javalenc
java
106
СоздатьДля создания публикации, пожалуйста в систему
