Community Member
unity 4x licensing
Can I use UNITY7-USR-E100 on a 4.21 unity system?
If not, are there part numbers for subscribers only, dont need ports. thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hall of Fame Super Silver
Re: unity 4x licensing
You cannot, the licensing for Unity 7 is slighly different from version 4. Just get the UNITY-VM-USR license.
Chris
Community Member
Thanks. This helped alot. do you know if there a s "version 5" form of this document?
thanks
137
