07-08-2010 11:07 AM - edited 03-15-2019 11:37 PM
Does Unity 5.0.1 Unified Messaging without failover support a partner 2010 Exchange server? If so, do I need to run any upgrade or patches on the current version or would you recommend upgrading to Unity 7.0.2?
Jaime
Solved! Go to Solution.
07-08-2010 11:11 AM
You can, read this:
•Exchange 2010 on a separate server
To use Exchange 2010 with Cisco Unity, you must install Cisco Unity 5.0 Engineering Special (ES) 85 or later. For information on downloading the ES and procedures for configuring Cisco Unity to use Exchange 2010, see Using Microsoft Exchange 2010 with Cisco Unity Versions 7.0 and 5.0 at http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/using_exch2010/usingex2010withcu7x5x.html.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/requirements/50cusysreq.html#wp472166
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
07-08-2010 11:11 AM
You can, read this:
java
