Unity 5.0.1 Partner Exchange Server
Does Unity 5.0.1 Unified Messaging without failover support a partner 2010 Exchange server?  If so, do I need to run any upgrade or patches on the current version or would you recommend upgrading to Unity 7.0.2?
Jaime
1 ACCEPTED SOLUTION
Re: Unity 5.0.1 Partner Exchange Server
You can, read this:
Exchange Requirements—Message Store
Exchange 2010 on a separate server
To use Exchange 2010 with Cisco Unity, you must install Cisco Unity 5.0  Engineering Special (ES) 85 or later. For information on downloading the  ES and procedures for configuring Cisco Unity to use Exchange 2010, see  Using Microsoft Exchange 2010 with Cisco Unity  Versions 7.0 and 5.0 at http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/using_exch2010/usingex2010withcu7x5x.html.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/requirements/50cusysreq.html#wp472166
Using Microsoft Exchange 2010 with Cisco Unity  Versions 8.0, 7.0, and 5.0
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
You can, read this:
java
java
357
