Unity 5.0(1) VoiceMail Port Registration
With a Primary & Secondary Unity server network attached to a Unified CallManager 6.0(1), when you failover from the Primary to Secondary, should the voicemail ports disconnect, or stay registered to the CallManager?
1 REPLY
Re: Unity 5.0(1) VoiceMail Port Registration
It depends on what type of failover you are doing. If you are using the failover monitor then yes the ports stay registered. If you stop unity or reboot then no they will become unregistered.
182
