12-01-2008 02:11 PM - edited 03-15-2019 02:51 PM
I have an active directory 2003 running on a 64 bit windows 2008 server as my global catalogue. I am getting a windows error when trying to run the ADSchemaSetup.
Microsoft Windows
ADSchemaSetup Executable has stop working
Windows can check online for a solution to the problem.
Here is the text from the details pane:
Problem signature:
Problem Event Name: APPCRASH
Application Name: ADSchemaSetup.exe
Application Version: 5.0.0.18
Application Timestamp: 4665170e
Fault Module Name: kernel32.dll
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791a81d
Exception Code: e06d7363
Exception Offset: 0002f35f
OS Version: 6.0.6001.2.1.0.272.7
Locale ID: 1033
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
Anyone have any insight?
01-06-2009 04:26 AM
We have run into this same issue and we resolved it by moving the Schema master FSMo to a 32bit machine, running the Schema update on that machine and then moving the role back
We were told that the schema update would not work on a 64-bit machine.
01-06-2009 07:19 AM
That is exactly what I ended up doing to work around my issue as well.
Well done.
01-09-2009 07:57 AM
i just ran into the same issue
by reading the thread i see that they move the
schema fso role to a 32 bit windows 2008 server is that correct
01-09-2009 07:59 AM
has anyone had the issue having exchange 2007
running on windows 2008 as well?
01-12-2009 06:49 AM
You need exchange sp1 rollup 4 or later.
here is rollup 4
Randy
01-12-2009 06:55 AM
rollup 5 is out now also.
Randy
