Community Member
Unity 5.0 and Outlook Inbox Full Issue
1) Does anyone know how to configure unity to prompt callers that their Outlook Inbox is full?
2) Caller A calls caller B internally and leave a voice message but caller A outlook inbox is full. Can caller B receive caller A voice message in this case?
Jimmy
Re: Unity 5.0 and Outlook Inbox Full Issue
I believe it keys off the limits set in exchange for the users inbox size. When they try to listen to messages through their phone and they are over the size limit unity will play a message saying as much. In our environment even if the inbox is full they still receive the message but if it is set in exchange to not allow anything more above the size limit then they will not get it.
This is true.  Everything is triggered off the Exchange rules.  If you control Exchange, you have some room here.  If not, which is typical, you'd have to work with them if changes are needed.
Hailey
Please rate helpful posts!
Community Member
Any specific Rules that people use for exchange that they want to share.
Thank you
Community Member
Thank you Tracy! It was helpful information.
Jimmy
181
