Unity 5.0 from exchange to domino
Gilberto Marcos
Hello guys I have a question.
Is there a way to change a unity 5.0 from exchange to Domino without installing again the unity application, or I have to reinstall all using the software for Lotus domino?
Thanks for your help.
Rob Huffman
Hi Gilberto,
Migrating from Cisco Unity for Exchange
Cisco Unity for Exchange systems, configured either for Voice Messaging or Unified Messaging, can be converted to Cisco Unity 5.0 for Domino, but only by reinstalling all software, and losing Cisco Unity settings and voice messages.
Designing a Cisco Unity System with Domino as the Message Store
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/design/guide/5xcudg050.html
From Lindborg @ Cisco (this is the definitive answer :)
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&topicID=.ee835d2&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dde7ef0/0#select...
From Thomas @ Cisco
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&topicID=.ee835d2&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc17503/0#select...
Hope this helps! Sorry man,
Rob
Hi Rob,
Is Voice messaging with Lotus domino possible.I have a Lotus Domino environment. Going for UM will involve lot of management approvals. I am seeing if there is a chance to get the Cisco unity configured for VM with Lotus Domino.
-Prakash
Hi Prakash,
Sure, Voicemail only (not UM) configs are supported with Lotus Domino (check supported configurations in the doc below);
Hope this helps!
Rob
Hi Rob,
I understood from the document that Domino servers in voice messaging mode should be dedicated to serve voice messages.So there should be a dedicated server apart from Unity running Domino.
-Prakash
