10-29-2008 02:57 AM - edited 03-15-2019 02:13 PM
We are planning for a Unity with multiple phone systems (3 different MD 110 PABX'es, connected with PIMG Devices (Serial + Analog lines)
How does the Unity makes the link between the subscriber and a Phone system ?
Is this a parameter of a subscriber ?
Can you simply change that parameter if a subscriber migrates from one phone system to another. (for instance from Ericsson to CUCM)
Many Thanks for all comments on this,
Dirk
Solved! Go to Solution.
10-29-2008 08:41 AM
yes, every integration will get an ID and each subscriber will use one of those.
if you have only worked with 1 system integration you have never seen it, as it only appears when you have 2+ integrations.
when you create all the integrations if you go to the subscriber page you will see the integration ID at the bottom of that page and you can change it
java
if this helps, please rate
10-29-2008 08:41 AM
java
