Unity 5 - external calls getting NU tone
I have an issue where external calls to an IP Phone are failing when that tries to route to voicemail.
Internally - calls route fine and voicemail works. Externally - calls come into the system on an E1 - get forwarded on busy or no answer to Unity and the end caller gets an NU tone. In Call viewer in Unity - you can see the call hitting the system twice in quick succession with a duration of 0 or 1 second.
Here is a Q931 debug:
Jun 22 14:32:05.416: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x5FB8
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98385
Exclusive, Channel 5
Progress Ind i = 0x8581 - Call not end-to-end ISDN, may have in-band inf o
Calling Party Number i = 0x1083, '4477165403999'
Plan:Unknown, Type:International
Called Party Number i = 0x81, '2997'
Plan:ISDN, Type:Unknown
Jun 22 14:32:05.444: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xD FB8
PARRIPT001#
Jun 22 14:32:05.616: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0xDF B8
Progress Ind i = 0x8188 - In-band info or appropriate now available
Jun 22 14:32:06.308: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x DFB8
Cause i = 0x80AF - Resource unavailable, unspecified
Any ideas? I've looked at DSP resources, alternate extensions, rebooting the voice gateway, rebooting Unity, etc......!!
The gateway is a 2821. The IOS is 12.4-15T8 advipservices.
Cheers
Dave
Re: Unity 5 - external calls getting NU tone
MGCP or H323??
That error is usually because codec issues, what codec is Unity configured for and what codec the dial-peers or location?
java
if this helps, please rate
java
www.cisco.com/go/pdi
H323 gateway.
Dial peers are set to use G711u as preference 1. Unity is also set to use that as are the regions.
Any errors in unity's App Log for those calls??
java
java
I've seen this before when using UCM 5.1 and Unity Connection 2.0. The fix was as follows:
Choose Service > Service Parameters and click CallManager.
Scroll down to Disable Alerting Progress Indicator and set this parameter to True.
Full details at this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a0080094b01.shtml#problem2
This fixed my problem on UCM 5 but I now have the same problem with UCM 7 and Unity Connection 7 - unfortunately my previous fix hasn't cured it this time.
254
