Community Member
Unity 5 hardware compatibility
Although it is not in the hardware compatibility matrix, can Unity 5.0 be installed on an MCS7825-I1 CC1/IPC1
equipped with 2x72 GB drives?
Thanks in advance for any suggestions.
Denis
Community Member
Re: Unity 5 hardware compatibility
Denis:
The only supported platforms for unity 5.0 are the ones that are mention on the following link:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd802132ef.html
MCS-7825-I1-CC1 is for IPCC servers
MCS-7825-I1-IPC1 is for CUCM and NAC APPLIANCE
So you cannot use those servers to install Unity 5.0
Pls rate if this helps
Community Member
Thank you very much for confirming what I suspected.
Merry XMas and a Happy New Year
Denis
Community Member
No problem any time.
I hope you have also a Merry Xmas and a Happy New Year.
Viri
246
