Community Member
Unity 7.0 Forwarding Messages
I have Unity 7.0 with failover running exchange. I have two users that are unable to forward a message off to another user in the system but all other users work fine. The difference between these two users and the rest are they are Administrators. When they forward a message the system says it has been forwarded but the recipiant never recieves the message. I have run the port monitor and saw an error for message store after the forward prompt. I'm not a unity guy can I please get some ideas?
1 REPLY
Re: Unity 7.0 Forwarding Messages
Go to ADUC and compare the tabs for groups to which they belong and permissions, compare them to a working user. Maybe there is something extra or missing on those 2 users.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
166
