Unity 7.0 Installation
HI..
I am trying to install Unity 7.0 using config assistant wizard. I do not want to integrate it with Domino or Exchange currently and planning to integrate later on. However during installation, at Message Store option i am forced to select either Exchange or Domino. Is there any way i can do this withot Domino or Exchange.
Thanks in Anticipation.
Aj
VIP Super Bronze
Re: Unity 7.0 Installation
Not with the Unity product. It utilizes one of those two as its message repository. To be honest, if you are going to through the pain of installing that product, you should just integrate it from day one and be done. If for some reason you don't want to give the users single-inbox unified messaging you can create new accounts/mailboxes in a different message store.
Also, if you do not want to do unified messaging, you could also install Exchange on the Unity server. This was the old voicemail-only deployment model.
Please remember to rate helpful responses and identify helpful or
To follow up on Jonathan's response and to confirm his answer...
There is no Unity without Exchange or Domino integration.
Hailey
is the option to install unity in a Voice-Mail only deployment model available in unity 7 or the integration is a must?
It requires Exchange. Unity Connection is the standalone product.
Sent from my iPhone
thanks for the reply, appreciate it.
180
