tka
Unity 7.0 VoiceMail only installation
Hi ,
Do you confirm that it is not necessary to have an Exchange or Domino Server if we would like to implement Voicemail only with Unity 7.0 . As ingle MCS Server with Unity is sufficient (of course while shoosing the appropriate options).
best regards,
Re: Unity 7.0 VoiceMail only installation
no! of course you need either one!, it's mandatory to have a message store.
Exchange Requirements-Message Store
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/requirements/7xcusysreq.html#wp472166
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hall of Fame Super Red
Hi Ramzi,
Unity does require Exchange but if you are using VMO (Voicemail Only) and not UM (Unified Messaging) you can install Exchange "on-box" with Unity. Here is a good thread with some links and great advice from Tommer,Ginger, Randy and Tray from Cisco;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&topicID=.ee835d2&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbfed10
Hope this helps!
Rob
tka
First, thank you for your response.
For the license, it should be a licence of Unity for Exchange or both types (for Exchange and for Domino) are valid for VMO messaging ?
many thanks!
108
