Unity 7 installation
Hi All,
I'll be installing a new unity server release 7 next week but the environment does not include any domain controllers or exchange server. Is it possible to install it and run the auto-attendant feature without them? And if the decided later to install an active directory and an exchange server, should I have to reinstall the Unity server from scratch?
Samer
Re: Unity 7 installation
With Unity, you must have a Domain Controller and an Exchange Server. There
is no way around that. However, it is permitted to configure the Unity
server as the Domain Controller and Exchange server.
Check this link first:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/redirect/7xinstallupg
radeinfo.html
Then, I believe the install guide you are interested in is here:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/installation/guide/vm
exnofo/5xcuigvmenofox.html
Read the guide before doing anything and build an implementation plan.
There are ways to add an external DC and Exchange server. It is usually
better to start with an external DC/Exchange day one and then expand to
failover or even upgrade to UM. That being said, there are tools and
methods available to add the DC/Exchange later.
HTH.
Bill
Please remember to rate helpful posts.
On 9/4/10 2:33 PM, "samerg@sts.com.jo"
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Samer, Unity = Exchange/AD dependencies, period. You cannot install without having some form of AD/Exchange (or up until 8x Lotus/Domino) in place.  If you do not have this infrastructure, you should be installing Unity Connection.
Hailey
Please rate helpful posts!
164
