Unity 7 - License Errors
I'm trying to migrate users with the GSM tool. The GSM error with licensing issues.
When I go to launch the Licensing tool, I get this:
Error querying AvDOM.
Error number: 0x80040155
Source: avLic
Description: Method '~' of
object '~' failed
Same error comes up on either failover partner.
I have tried restarting the AvLic service to no avail. I haven't done a full reboot yet.
Any help would be great - thanks!
1 REPLY
Silver
Re: Unity 7 - License Errors
The error you are getting means no interface registered, so it could be possible the AvDomSvr.dll library isn't registered on the system. AvDOM is a component of Unity. You can try to use regsvr32 on that file to see if it has any change.
Try the following command; regsvr32
D:\Commsercver\components\AvPhraseServerSvr.dll
161
