Unity 7 - Menu Playback slow on one mailbox
Application: Unity
Version: 7.0
Platform: Windows Server 2003
Message Store: Exchange 2003
CUCM: CUCM v8.6
I have one user who has reported to me that when he is checking his voicemail, the menus play very slowly. Any clue where to start on this? I checked mailbox settings and could not find an option he could have pressed to make this so.
Jonathan Beardsley, CCNA Voice, MCITP
Telecom & Network Administrator
When you log in to Unity, go to "Subscribers".  Find the agent you are looking to adjust.
Under their profile you will see an option to adjust the "Conversation Speed".  You want to set that to "Normal".  Conversation speed is what controls the speed of the menu, greeting, etc.
Hall of Fame Super Red
Hi Brian,
I just wanted to add a bug reference to the great tips from Andrew (+5 Andrew )
CSCsz93254 - Provide a way to disable sticky playback speed keys
Description
Symptom:
Unity 7.0.2 message and prompt playback speed seems to be randomly faster or
slower than expected.  This is most commonly reported by users of a shared
mailbox.
Conditions:
Unity 7.0.2 introduces a new sticky key feature for Playback Speed.  This
behavior is not desirable for all users.  Following is a link to the release
notes describing this new feature.
Playback Speed Adjustments Are Saved Across Sessions
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/release/notes/702cur??elnotes.html#wp62222??
Workaround:
There is no workaround.
Further Problem Description:
It is important to note, this is the designed behavior of Unity 7.0.2.
However, this behavior is not desirable for all users.  This bug documents a
feature enhancement which will allow Unity 7.0.2 to behave similar to Unity 5.0.
To resolve this issue, a key called "Conversation - Do Not Save Speed Changes Made By Phone" has been added to the Advanced Settings Tool, which allows Administrators to disable the Sticky Speed feature. To make use of this key, you need to install 7.0 Engineering Special 29 or later, and download and install the latest version of the Advanced Settings Tool from www.ciscounitytools.com.
Details
1st Found-in:                          (1)
7.0(2)
Status:
Fixed
Last Modified:
Nov 25,2011
Fixed-in:                          (17)
8.0(1.32), 8.0(1.27), 8.0(1.20), 8.0(0.200)
7.0(2.0)ES42, 7.0(2.0)ES41, 7.0(2.0)ES40
7.0(2.0)ES39, 7.0(2.0)ES38, 7.0(2.0)ES37
7.0(2.0)ES36, 7.0(2.0)ES35, 7.0(2.0)ES33
7.0(2.0)ES32, 7.0(2.0)ES31, 7.0(2.0)ES30
7.0(2.0)ES29
Less
Product:
Cisco Unity Unified Messaging
Platform:
Dependent
Severity:
6 - enhancement
Customer Reported:                          (37)
Cheers!
Rob
490
