02-06-2012 04:46 AM - edited 03-16-2019 09:25 AM
We have Unity 7.x (Active/Standby HA) is running on MCS7835, we want to migrate to Ucnx 8.x on same server through UCSS
UNCN8-UTYMG-K9= 2 Upg/Mig from Unity Cxn 1.x/Unity 4.x or later to Unity Cxn 8
UNITYCN8-HA-PAK 2
I have couple of queries,
(1)Is these components are sufficeint ? Anything else needs to be ordered through UCSS ?
(2)Where is media for upg/Mig? Is it part of the above order ?
(3) What about subscriber license? license team will issue new Ucnx single-inbox license based on present license?
(4) Is there any revert back to previous version, possible in case of any problem during migration?
Rgds
Rajesh
Solved! Go to Solution.
02-06-2012 05:13 AM
(1) That looks good although you probably only need one each.
(2)It will be shipped as part of this order.
(3) The -HA license is for your subscriber. You need to upload all of your Unity mailbox-containing licenses to Connection . These are only server migration PAKs.
(4) Not when you reuse the same servers and hard disk. You can take. a DiRT backup before you begin to use for a recovery/reinstall of Unity though. Note that Connection typically requires memory and HD upgrades in most MCS models. Check the supported platforms guide to confirm.
02-06-2012 05:13 AM
