Unity 7.x with exchange 2k3 to 2k7
On the unity side, when migrating from exchange 2003 to 2007, is there anything that needs to be done?
1 ACCEPTED SOLUTION
Re: Unity 7.x with exchange 2k3 to 2k7
Hi!
First of all make sure your Unity version supports Exchange 2007! It should be 5.X or later as you have 7.X you are good to go!
Then, as the partner exchange server will be changed you will need to run the Message Store Configuration Wizard again and check the permissions too.
Please refer to this link, it covers the procedure you need to follow:
*** Upgrading Exchange 2000 or 2003 to Exchange 2007 for Cisco Unity 5.x Without Failover ***
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/ex/5xcuruge130.html#wp1359133
HTH!
Teresa.
If this helps, please rate :)
Regards, Tere. If you find this post helpful, please rate! :)
Just follow this link and you will be set on everything you need to make the transition.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/ex/5xcuruge050.html
Hi!
HTH!
Teresa.
146
