Unity 8.5 and HP Proliant DL180G6 issue
Dear All
I want to install unity connection 8.5 on the follwing HP server "HP Proliant DL180G6 E5606 2.13 GHZ 4 Core,   1x2GB Memory,   1x250GB,    P410,    2U"
is this server suitable to install Unity connection.
Thanks in advance.
Rashed.
Chris Deren
This is definitely not supported as bare metal hardware, you can see if it is supported as spec based virtualized server.
