Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Unity 8.5 default password
Afternoon all,
We have a two server here, which is due to go live in 3 days time.
We had issues when installing the locale and a TAC was opened, and a ES was installed
which over come the issue.
We are rolling out the phones now, and I have noticed that the default password which
currently worked for the phones that were "BAT'd" in now does not work. There are nearly a 1000
phones/VM so this is a considerable amount of work that needs to be done if this is to be
done manually.
I have looked on CCO and found this
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/user_mac/guide/8
xcucmac040.html#wp1442255however these instructions are not accurate and do not help in this issue.
Does anyone have any idea how to bulk change the default password so the new users can acess their VM accounts?
Cheers.
Green
Re: Unity 8.5 default password
The document is for Unity Connection 8.
Is this what you are using or is it UNITY 8.5
For UNITY
On the server desktop
Unity Tools Depot
Bulk Edit
Select your users
Use the PASSWORDS TAB
Alex
Regards, Alex. Please rate useful posts.
hi there, this is for connections!
Hall of Fame Super Red
Hi Carl,
What part of the Bulk Edit does not work?
Cheers!
Rob
Hello Rob,
if I go to user> select all > click on bulk edit at the bottom and then click on change password. I run this but the password is not what I have changed it to!
Hi Carl,
I had a look in the Bug Toolkit/BSS and there are quite a few bugs related to
Bulk Edit in CUC 8.5. Not one specifically related to PIN's, but I would go ahead and open a
TAC case just to be sure here
Cheers!
Rob
Cheers Rob!
Bronze
Just to make sure. You are going down to the bottom of the page and clicking the "Select all (number of users)", correct?
Also, are you talking about the PIN or the Web password? If PIN, that comes from the User template that you associated with the user.
Gareth
Green
Hi Carl,
I had a wee look at this my lab today.
Make sure that is the PIN for voicemail and not the WEB App you select.
Also once you have hit the "SUBMIT" button you can look at the
job status in the "TASK MANAGEMENT" page.
You should see your jobs listed here.
Pick your job and click on the end time, this will
download the results on a seperate page.
You should see the reason why your job failed.
May be something like the POIN was to short or not complex
E.g.
1234 may be regarded as unsecure or not long enough whereas
147258 may be acceptable.
Alex
348
