Community Member
Unity after intallation issue
Good day!
I have installed Unity 4.0.5, no error occured during installation after this unity not starting - error number 0x8004330E (connection could n't established with Unity database). SQL server is started and working fine. When I look with enterprise manager occured that theres is no UnityDB at SQL.
This is my first time when I'm installing unity. So my question is UnityDB must be created manualy or automatic during installation and how to fix this?
Thank you!
1 REPLY
Re: Unity after intallation issue
unityDB should have been created during the install, if this is a new deployment i'd suggest reinstall from scratch
java
if this helps, please rate
java
www.cisco.com/go/pdi
128
