Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Unity and Active Directory integration
i have a scenario where unity was installed and integrates with corporate AD. Now this server does not exist any more and i need to clean the AD from the attributes added by Unity.
any one knows a way of doing so!!
Good day
Re: Unity and Active Directory integration
Unity uses Exchange. You need to follow the microsoft instructions on removing an Exchange manually from AD. It will require you to run ADSIEDIT.
Here is the link...
http://support.microsoft.com/kb/260378
Gold
When you extend the schema for Unity, the attributes added are listed under Table 5 and 6 at http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/whitpapr/datadir.htm#wp1095387
You can remove the values set for this attributes for all Unity subscribers. You cannot delete the fields as a limition with AD is that any changes to the schema cannot be removed.
297
