Unity and G.729
Can Unity 5.0 support either G.711 or G.729? Or can it support both codecs at the same time (so vm for remote users can travel wan via g.729 and local G.711 on lan).
thanks
1 REPLY
Hall of Fame Super Silver
Re: Unity and G.729
yes, Unity supports both codecs, however prompts and vm recordings will be stored in the codec you selected during install. Unity can do native transcoding to the other codec, but it puts overhead on the server, so hardware xcoder may be a better solution.
HTH,
Chris
104
