Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Unity Auto Attendant - Routing when a subscriber is not forund
I have an auto attendant set up for a site that allows caller input.
If the extension does not exist unity responds with "I did not recognize that as a valid entry" and gets routed to the opening
greeting. I want to route this to the sites operator but can't figure out how to
accomplish that. I played around with the routing rules a bit but I was still unable to get the call to route correctly.
<br />
<br />
Re: Unity Auto Attendant - Routing when a subscriber is not foru
you need to configure a caller input to a call system transfer, then from there dial any DN you want
java
if this helps, please rate
java
www.cisco.com/go/pdi
No what I want to happen is if the extension is invalid I want the call to automatically route to an operator.
just change accordingly to your needs
Unity Voicemail: Repeat the Same Greeting when an Invalid Key is Pressed
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_configuration_example09186a00806557c6.shtml
java
java
Awesome! I didn't even know this setting existed. 5 to you!
185
