Unity Backup using Script
Is there any way to take a backup in Unity 4.2 using Script?
Reason - Unity does not store the daily backup with the current date. instead, it over writes backup in the same folder. So, i would like to run a script through which i can take daily backup with the naming as the current date and store in the remote Server.
Please let me if any of you have script for automatic Backup in unity 4.2?
1 REPLY
Re: Unity Backup using Script
Download and install COBRAS and configure a scheduled task to run it. Works good for me.
Hope this helps.
124
