Community Member
Unity Backups Created multiple times
Hey guys!
Just wondering if anyone has run into an issue of their Unity backups being performed 2-3 times when it was only scheduled once.
So if it is scheduled to backup at 6:05AM it will run successfully three times at 6:05, 6:10 and 6:12. There are not warnings in the backup history. Any help would be awesome. Thanks!
Everyone's tags (2)
Hall of Fame Super Red
Hi Craig,
Can you please clarify if this is Unity or Unity Connection and the exact version
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Community Member
Hey Rob!
We are running Unity Connection
Version 7.1.2.20000-140
Ever heard of this issue before?
Hi Craig,
Do you have multiple Message Stores configured? If so, I blieve this is working as designed
Cheers!
Rob
Community Member
Hey Rob,
If you look at the linked screenshot it shows the backups being completed individually at first. Then suddenly it starts creating multiples come the 19th.
http://i.imgur.com/CVWfI.png
Hi Craig,
Yeah...that's very weird!
It looks like it's gone to 3 per night now I've looked for bugs that might explain this
behavior and have come up empty.
I would really try to move this to a TAC case at this point. We really had some crazy things happen
when we were running 7.1(2) it was a very buggy build. You might want to look at upgrading to
7.1(3b)su2 as it has been an extremely solid build.
Sorry man! You could also try a re-boot as a first step as well.
Cheers!
Rob
Community Member
Funny today I have found one of my customer cluster doing the same but with CUCM 7.1.5.31900-3
I have restarted the DRF Master after looking in the logs without finding anything. I will update later
Since I am going to holidays and it is not critical I will check on my return.
Christian
Screenshot below:
Community Member
Hey just an update on my case for future reference. All I had to do was restart the DRF Master service and everything is functioning as it should. Thanks!
Hey Craig,
Thanks for posting back with your results here! +5 for this very
kind gesture
Cheers!
Rob
504
