Unity Bulk Reset Tool in Unity 5.0(1)?
Unity Bulk Subscriber Reset Tool was removed in Unity 5.0(1), does anyone know if this tool is being updated for 5.0(1)?
Re: Unity Bulk Reset Tool in Unity 5.0(1)?
Don't you mean Unity Bulk Subscriber Edit Tool?, that tool should be on under Tools Depot.
Then if you don't find it you can download the tool from this website.
http://www.ciscounitytools.com/4_x_tools.htm
Thanks for replying, I need the bulk subscriber rest tool, it is further down the page on the link you posted. I really appreciate the response though. I hope they eventually come out with a version for 5.0(1).
the tool is not currently supported for any Unity 5.0(1) or higher versions
http://www.ciscounitytools.com/App_BulkSubscriberReset.htm
Compatibility
Unity 4.0(3) through 4.2(1)
NOT supported on Unity 5.0(1) and later at this point.
no time frames at this point
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks for replying, hopefully they will come out with it for 5.0(1) soon
107
