Unity call forward issue with redirecting number
Dear Cisco Support Team,
I am having issue with redirecting number from PSTN to one of the main DID number.
I have running unity for call handler and everything is working fine.Recently i transfered one normal line to Pilot number of our company from telco.When call hits the gateway as seen below.
   Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Facility i = 0x91A1220202008002010F30190201010A0101A111A00FA10D0A010212083232363632303030
                Protocol Profile = Remote Operations Protocol
                0xA1220202008002010F30190201010A0101A111A00FA10D0A010212083232363632303030
                Component = Invoke component
                        Invoke Id = 128
                        Operation = Diversion Leg2
        Calling Party Number i = 0x2181, ''
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, ''
        High Layer Compat i = 0x9181
Jul  4 14:24:41.253: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x80EB callID = 0x00C7 switch = primary-net5 interface = User
Jul  4 14:24:41.253: ISDN Se0/0/0:15 Q931: extract_redirect_orig_called_ie: IE type redirecting num  reason 15 cnt 1 plan 2 type 1 pres 0
Jul  4 14:24:41.269: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x80EB
its hits the call handler and play the opening greeting but when i checked the call view in unity it showed the rediretcted number in the call view.Instead of Pilot number that is 7777.
Any suggestion
Advise.
Everyone's tags (5)
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Hi, this is working as expected. Unity will use the first redirecting number which is the main line number that transfered to the pilot. You can resolve this by adding the mainline number as an alternate extension to the pilot number in unity or configure a routing rule in unity.
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
You need to create a routing rule in unity. like this. When the forwarding station=22662000, send the call to opening greeting for callhandler 7777. Thats what you need to do
VIP Super Bronze
Re: Unity call forward issue with redirecting number
Dear Aokanlawon
Thanks alot for your prompt reply.
I have redirected number that is 2246XXXX to the pilot number 7XXX.When i am calling from PSTN to 2246XXX it redirect this number to 7XXX and then it plays the opening greeting but when i am calling from PSTN to direct my pilot number 7777 it plays the normal call handler.
I have attached the snapshot for call view.
Please have a look on it and advise.
Thanks.
VIP Super Bronze
Thanks Aokanlawon
I have made changes as you said in the above post and its working.
I rate the posts
Thanks Alot
Appreciate.
Dear Aokanlawon
The customer requested the calls to be recoreded  means he wants to record some specific calls when he needs.
When i reviewed the unity licensing i found the feature Message recording Full Length is licensed.
Can i use this feature to record the calls or specific calls when required.
Kindly confirm if i can use the same feature to record the calls.
i have attachecd the snapshot for unity license.
Any document on this will help.
Jamil Hussain
VIP Super Bronze
That license is not for call recording. It is for voice messages. You Cant use unity to record. You need an 3rd party software to record calls
889
