Unity Call Handler Send Caller to Hangup issue
Unity Version: 4.2(1)
CallManager Version: 4.2(3)
Configuration:
Call Handler Greetings
Source: Blank
After Greeting: Send caller to Hangup
CallManager Device Phone
Line Configuration
Directory Number: 125
Call Forward Pickup Settings
Forward No Answer Internal: Voicemail
Forward No Answer External: Voicemail
No Answer Ring Duration: 30 Seconds
Symptoms:
Placing a call to 125 from an internal Cisco IP Phone or calling POTS line connect to FXO (plar to 125) results in the following:
Ring for 30 seconds
call forwarded to Call Handler
call handler Hangup the call
caller receives a fast busy
Why does the call receive a fast busy? Normally that would not be an issue, because the caller would simply hangup when hearing the fast busy..
However, in this application, the plar FXO is connected to the Valcom front door bell button/speaker.. The person who pressed the front door bell button hears 30 seconds of ringing (expected) and then begins to hear the fast busy.. He/She cannot hangup the front door bell button
Does anyone know how do correct this behavior, or reduce the fast busy to 5 seconds or less?
Hall of Fame Super Red
Re: Unity Call Handler Send Caller to Hangup issue
Hi Rob,
I have never tried the "Door Bell/Speaker" setup with Valcom, but I thought this was a very interesting question :) My guess here is that you are running into a "Disconnect Supervision" issue on the FXO. You need to try and determine what method of disconnect the Unity is using (my first thought would be Tone disconnect) Once the method has been determined, you can configure the FXO appropriately. Have a look;
FXO Disconnect Supervision
http://www.cisco.com/en/US/products/sw/iosswrel/ps5013/products_feature_guide09186a0080080e48.html#wp7602
Hope this helps! I know it doesn't answer your question completely but maybe it will head you in the right direction.
Rob
Thank you for the insight, and the link..
I will give that a try and let you know how it works out..
Rob
CCIE #15410
176
