Unity Caller input for #11
Is it possible to set a caller input for number 11 in unity call handler? I have used 1 to set as ignore key since there are other numbers like 15 and 16 used in the same call handler. Is there a work around for this?
1 REPLY
Re: Unity Caller input for #11
other than create a separate caller input and use it, no, if you want to dial 11 you can't configure 1 to ignore that key.
java
if this helps, please rate
java
www.cisco.com/go/pdi
102
