Unity Caller Input
bbtekgraf
Using Unity 4.2
We have a Call Handler set to answer an 800 number and the Caller Input is set to allow callers to dial an extension during greeting. If they enter an invalid extension, how do I control where the call goes? Is this possible? Currently, the recording plays “I do not recognize that as a valid entry” and routes the call to the Opening Greeting which might confuse some customers.
Thank you for any assistance.
Jaime Valencia
Read this doc as example, you can change it as you wish
Unity Voicemail: Repeat the Same Greeting when an Invalid Key is Pressed
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_configuration_example09186a00806557c6.shtml
java
if this helps, please rate
java
Jaime Valencia
java
java
awesome.
just what i needed java.
thank you for the quick responses.
training videos from jeff lindborg and the flying monkey squadron always help too.
ciao
Rob Huffman
Hi Brett,
This is from Unity Design Engineer Jeff Lindborg;
"You can expose the error greeting in the SA interface using the Advanced Settings tool. You can also use BulkEdit to do the for all your handlers and subscribers if you like - there's a special option called "loop back to self" for the error greeting option that's made just for this type of thing." Jeff
Hope this helps!
Rob
