Unity can't transfer to Translation pattern now
Hi I am using ccm 4.1.3 and Unity 4.2.1.
We use to be able to call 5100(call handler) and be able to transfer to a translation pattern(used for speed dial to cell phone) and extensions.
Now only the ext can be dialed. When I dial a translation pattern, the lady says, "I did not reconize that as a valid entry."
Any help is appreicated.
Randall
1 ACCEPTED SOLUTION
Re: Unity can't transfer to Translation pattern now
Randall,
Sounds like at one time the DN for these translation patterns was associated with a Unity subscriber. By default, you can only dial DNs associated with subscribers. If you need to allow callers to dial extensions not associated with a subscriber, take a look at the following post.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc1ebec/3#selected_message
Hope this helps.
Brandon
Randall,
Hope this helps.
Brandon
Brandon,
Thank you very much!
You do better searches. :)
Randall
Hello Brandon,
as Im unable to open the link that you posted is there another way that you can share me the info?
It will be very appreciated,..
Take a look at the following doc regarding setting up Caller System Transfers.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag115.pdf
Hope this helps.
Brandon
203
