Unity Cluster
I'm deploying unity connection 8.6 as a cluster- do I need two SIP trunks in CUCM pointing at each server or can I use one trunk  with both Unity IP addresses?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Unity Cluster
Hi Ian,
We run SCCP but it does look like 2 SIP Trunks are required
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/integration/guide/cucm_sip/cucintcucmsip060.html#wp1132738
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Hall of Fame Super Silver
Unity Cluster
You could do 1 trunk with 2 destination IP addresses, but I normally do 2 separate trunks and control the order via route groups.
HTH,
Chris
Unity Cluster
Hi Ian,
Cheers!
Rob
- The Band
Unity Cluster
HTH,
Chris
112
