Unity & CME Integration Issue
Hi Friends,
I've a small question,
I have a Cisco 3845 (CME) With a service module (Voicemail)
Here is the question,
I've configured CME ip on Gigabit Ethernet 0/0 (172.17.2.6/24) & now I want to configure Service Engine
If I say, ip unnumbered GE0/0
& say
FramedRelay-CME#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
FramedRelay-CME(config)#interface Service-Engine2/0
FramedRelay-CME(config-if)#ip address 172.17.2.7 255.255.255.0
% 172.17.2.0 overlaps with GigabitEthernet0/0
Or If I try to configure the default gateway, it says
FramedRelay-CME(config-if)#service-module ip default-gateway 172.17.2.1
Default gateway is not reachable for service-module Service-Engine2/0
I read accross a document which says,
"The Cisco Unity Express module connects to its host router via a back-to-back Ethernet configuration that physically travels across the backplane of the router. " - Do I have to change the Interface from GE to Fast Ethernet? I dont have different Vlan, all falls in 172.17.2.x/24
Sylvester
Siemens
Everyone's tags (2)
1 ACCEPTED SOLUTION
Super Bronze
Re: Unity & CME Integration Issue
You're close - the
Ip address
Command sets the IP of the interface on the ROUTER, not the CUE module - .. that's done by the command:
Service-module ip address x.x.x.x x.x.x.x
For example:
interface FastEthernet0/0
backup interface FastEthernet0/1
ip address 10.195.233.130 255.255.255.192
duplex full
speed 100
service-policy output Voice-Policy
interface Service-Engine0/0
ip unnumbered FastEthernet0/0
service-module ip address 10.195.233.132 255.255.255.192
service-module ip default-gateway 10.195.233.130
You then need a host route to push traffic out the service-engine interface to the CUE IP:
ip route 10.195.233.132 255.255.255.255 Service-Engine0/0
Aaron
Please rate helpful posts....
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
You're close - the
Ip address
For example:
duplex full
speed 100
Aaron
That was helpful, reply is much appreciated.
Now its fine,
FramedRelay-CME#service-module Service-Engine2/0 session
Trying 172.17.2.6, 2130 ... Open
CUE>
CUE>
CUE>
CUE>
1218
