Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Unity Cobras Migration
I have a Unity 4.X enviroment with Voicemail only. Can COBRAS migrate that existing data to Unity 7.X in a UM enviroment?
Re: Unity Cobras Migration
Yes you can, just as DIRT before you can move UM/VMO backups
java
if this helps, please rate
java
www.cisco.com/go/pdi
You can pull down the appropriate version ov COBRAS from answermonkey.net There are 2 variations. Import and Export. Install the Cobra export tool and run it. You will be prompted for what type of data you would like to export such as greetings, callhandlers, etc. Once you install unity version 7 you will install the Import version of Cobra and import the data from the original export.
This tool works great. You may know already but you can import a dirt backup to a different version of Unity.
Can you explain how its done?
247
