Community Member
Unity Conn Automatic Transfer
I am confused on creating a Auto Transfer in Unity Conn 7
What I am attempting to do is to Provide a number Via CTI Route Point (which works) the create a System Call Handler that works with a Scheduler and if it meets a certain time forward the call to a singe phone, or at another time forward the call to a Hunt Group.
I am unable to make a call transfer back out of Unity (without caller input) to a DN. from what I have read Do I need to create 2 System Call Handlers to make this work???
What I am doing is: CTI --> CH --> DN
But is this what I should be doing: CTI --> CH --> CH --> DN???
Confused and Tired, Thanks
Neal
Everyone's tags (4)
Re: Unity Conn Automatic Transfer
With that method of CTI you need 2 CHs.
The 1st one on which you receive the call and in after greeting action you configure attempt transfer to
And the 2nd CH on which the transfer options are set to Yes, ring subscriber at this extension.
If you want to use only 1 CH you need call routing rules (drop CTI RP matching CH) on which you can configure the attempt transfer option.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Thanks for the help. It worked as soon as I turned the Alternate Greeting off.....
316
