Unity Connect Call Handler - One Way Audio After Transfer
Newly setup CUCM and UC 10.5, I have a translation rule on a CUBE that sends all inbound calls to a certain number to a system call handler on Unity Connection. Calls come from a SIP trunk provider. UC is integrated to CUCM using SCCP.
The inbound call is sent to the call handler, I am prompted to pick a single number option or enter an extension. Picking either of these results in a transfer, the transfer rings the proper phone but when I pick up the called phone the calling party can't hear me, rather they just continue to hear the music on hold. I can however hear the calling party audio on the called phone.
I can't figure out why the music on hold doesn't stop after the called phone is picked up.
Additional Details:
  • I have changed the translation rule on the CUBE to forward the call to just a normal DN of my desk phone, and there is two way audio as there should be.
  • Voicemail boxes exist on UC and users can record their name and greetings using their phones, indicating that UC is able to get audio from the phones.
  • If I call the call handler DN from an internal phone and hit an option for a transfer the audio works fine, it is just calls coming from CUBE/the SIP provider that have issues.
I'm very confused at this point, any advice is appreciated.
Everyone's tags (1)
What codec is your call from
What codec is your call from the SIP provider? Can you post your configuration?
What about routing
What about routing information? I have seen where the signaling is working but the RTP path is not established due to not having a route.
Should have mentioned this
Should have mentioned this before, but thank you for the help, it is appreciated!
Routing between CUBE and CUCM + UC seems okay, I can ping the CUBE from CUCM and UC, and vise versa.
Additionally there are also no ACL's into the voice VLAN, and the only ACL's on the router are configured to allow all SIP traffic from the provider, enabling logging of all dropped packets indicates there is no packets being dropped at CUBE due to an ACL.
Did a capture by enabling
Did a capture by enabling SPAN on the PC port of the phone the call is transferred to through UC, I see the SIP call control messages and then I start seeing RTP audio packets between the phone's IP address and the IP address of CUBE.
I take it this points to the issue being MOH not being stopped on the calling side than really being a one way audio issue...?
In addition to this the MOH
In addition to this the MOH isn't coming from CUCM, when I disable the MOH server on CUCM the MOH is still there. So the MOH is coming from UC somewhere, almost like the call is stuck in some queue waiting to be transferred.
Hi.Can you please activate a
Hi.
Can you please activate a debug ccsip message on cube and post the output of a non working call?
Please let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Note the following: I have replaced the calling parties number with 11111111111, and I have replaced the called parties number with 2222222222.
Let me know if you need anything else.
As requested:
039403: Aug 28 09:08:57.477 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2222222222@184.71.242.2:5060 SIP/2.0
Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK0f298422;rport
From: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80
To: <sip:2222222222@184.71.242.2:5060>
Contact: <sip:1111111111@208.43.85.75>
Call-ID: 150b67c355dd6cc774ad4bca7944ca5b@208.43.85.75
CSeq: 102 INVITE
User-Agent: Asterisk PBX
Max-Forwards: 70
Remote-Party-ID: "1111111111" <sip:1111111111@208.43.85.75>;privacy=off;screen=no
Date: Thu, 28 Aug 2014 15:08:57 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Content-Type: application/sdp
Content-Length: 361
v=0
o=root 1022 1022 IN IP4 208.43.85.75
s=session
c=IN IP4 208.43.85.75
b=CT:384
t=0 0
m=audio 18910 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
m=video 18520 RTP/AVP 34 99
a=rtpmap:34 H263/90000
a=rtpmap:99 H264/90000
a=sendrecv
039404: Aug 28 09:08:57.485 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M6a
Content-Length: 0
039405: Aug 28 09:08:57.489 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:3000@10.135.191.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.0.1:5060;branch=z9hG4bK1B6512A3
Remote-Party-ID: "1111111111" <sip:1111111111@172.18.0.1>;party=calling;screen=no;privacy=off
From: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1
To: <sip:3000@10.135.191.12>
Call-ID: 11667682-2DFC11E4-92F4CC10-65967311@172.18.0.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0291807601-0771494372-2465123344-1704358673
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1409238537
Contact: <sip:1111111111@172.18.0.1:5060>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 393
v=0
o=CiscoSystemsSIP-GW-UserAgent 8203 267 IN IP4 172.18.0.1
s=SIP Call
c=IN IP4 172.18.0.1
t=0 0
m=audio 18666 RTP/AVP 0 101
c=IN IP4 172.18.0.1
a=fmtp:101 0-16
a=ptime:20
m=video 18668 RTP/AVP 34 119
c=IN IP4 172.18.0.1
a=fmtp:34 CIF=1
a=rtpmap:119 H264/90000
a=fmtp:119 profile-level-id=000000
039406: Aug 28 09:08:57.497 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
039407: Aug 28 09:08:57.505 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Server: Cisco-CUCM10.5
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "Cisco Unity" <sip:2000@10.135.191.12>
Remote-Party-ID: "Cisco Unity" <sip:2000@10.135.191.12>;party=called;screen=yes;privacy=off
Contact: <sip:3000@10.135.191.12:5060>
Content-Length: 0
039408: Aug 28 09:08:57.509 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36
CSeq: 102 INVITE
Remote-Party-ID: "Cisco Unity" <sip:2000@184.71.242.2>;party=called;screen=yes;privacy=off
Contact: <sip:3000@184.71.242.2:5060>
Content-Length: 0
039409: Aug 28 09:08:57.617 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow-Events: presence, kpml
Supported: replaces
Session-Expires:  1800;refresher=uas
Require:  timer
Contact: <sip:3000@10.135.191.12:5060>;isFocus
Content-Length: 408
v=0
o=CiscoSystemsCCM-SIP 100429 1 IN IP4 10.135.191.12
s=SIP Call
c=IN IP4 10.135.191.13
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
m=audio 16838 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
m=video 0 RTP/AVP 31 34 96 97
a=rtpmap:31 H261/90000
a=rtpmap:96 H263-1998/90000
a=rtpmap:97 H264/90000
a=content:main
a=inactive
039410: Aug 28 09:08:57.621 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:3000@10.135.191.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.0.1:5060;branch=z9hG4bK1B66BC6
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
039411: Aug 28 09:08:57.625 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Contact: <sip:2222222222@184.71.242.2:5060>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 292
v=0
o=CiscoSystemsSIP-GW-UserAgent 7259 1403 IN IP4 184.71.242.2
s=SIP Call
c=IN IP4 184.71.242.2
t=0 0
m=audio 18662 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
m=video 0 RTP/AVP 34
039412: Aug 28 09:08:57.709 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:2222222222@184.71.242.2:5060 SIP/2.0
Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK1f4d545e;rport
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
039413: Aug 28 09:09:03.221 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1111111111@172.18.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1b5396f4b2
From: <sip:3000@10.135.191.12>;tag=100429~dc062259-9b0a-4df2-b05d-e4de329c1980-28525423
To: "1111111111" <sip:1111111111@sip1.ixica.com>;tag=A7CF398-21B1
Date: Thu, 28 Aug 2014 15:09:03 GMT
Supported: timer,resource-priority,replaces
User-Agent: Cisco-CUCM10.5
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Session-Expires:  1800;refresher=uac
Min-SE:  1800
Remote-Party-ID: "Cisco Unity" <sip:2000@10.135.191.12>;party=calling;screen=yes;privacy=off
Content-Length: 414
v=0
o=CiscoSystemsCCM-SIP 100429 2 IN IP4 10.135.191.12
s=SIP Call
c=IN IP4 0.0.0.0
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
a=ptime:20
a=inactive
a=fmtp:101 0-15
a=content:main
a=inactive
039414: Aug 28 09:09:03.229 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
039415: Aug 28 09:09:03.229 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1111111111@208.43.85.75 SIP/2.0
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B678C7
From: <sip:2222222222@184.71.242.2:5060>;tag=A7CF3A8-B36
To: "1111111111" <sip:1111111111@208.43.85.75>;tag=as40beef80
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1409238543
Expires: 180
Content-Length: 294
v=0
o=CiscoSystemsSIP-GW-UserAgent 7259 1404 IN IP4 184.71.242.2
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
c=IN IP4 0.0.0.0
a=inactive
a=fmtp:101 0-16
a=ptime:20
039416: Aug 28 09:09:03.313 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B678C7;received=184.71.242.2
CSeq: 101 INVITE
Supported: replaces
Content-Length: 0
039417: Aug 28 09:09:03.313 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 310
v=0
o=root 1022 1023 IN IP4 208.43.85.75
s=session
b=CT:384
t=0 0
m=audio 18910 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=inactive
a=inactive
039418: Aug 28 09:09:03.321 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1111111111@208.43.85.75 SIP/2.0
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6822DC
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
039419: Aug 28 09:09:03.321 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Remote-Party-ID: "1111111111" <sip:1111111111@172.18.0.1>;party=called;screen=no;privacy=off
Contact: <sip:2000@172.18.0.1:5060>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 295
v=0
s=SIP Call
c=IN IP4 172.18.0.1
t=0 0
c=IN IP4 172.18.0.1
a=inactive
a=fmtp:101 0-16
a=ptime:20
c=IN IP4 172.18.0.1
039420: Aug 28 09:09:03.325 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:2000@172.18.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1c60c9dcc9
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
039421: Aug 28 09:09:03.337 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2000@172.18.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1d54678d26
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Min-SE:  1800
Content-Length: 0
039422: Aug 28 09:09:03.341 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
039423: Aug 28 09:09:03.341 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B691481
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
039424: Aug 28 09:09:03.421 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B691481;received=184.71.242.2
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
039425: Aug 28 09:09:03.421 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 361
v=0
o=root 1022 1024 IN IP4 208.43.85.75
s=session
b=CT:384
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
a=sendrecv
039426: Aug 28 09:09:03.429 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 393
v=0
o=CiscoSystemsSIP-GW-UserAgent 8203 268 IN IP4 172.18.0.1
s=SIP Call
c=IN IP4 172.18.0.1
t=0 0
c=IN IP4 172.18.0.1
a=fmtp:101 0-16
a=ptime:20
m=video 18670 RTP/AVP 34 119
c=IN IP4 172.18.0.1
a=fmtp:34 CIF=1
039427: Aug 28 09:09:03.441 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1e4ad4139
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 380
v=0
o=CiscoSystemsCCM-SIP 100429 3 IN IP4 10.135.191.12
s=SIP Call
c=IN IP4 0.0.0.0
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
a=X-cisco-media:mmoh
a=ptime:20
a=inactive
a=content:main
a=inactive
039428: Aug 28 09:09:03.441 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc1f64c64759
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Min-SE:  1800
Content-Length: 381
v=0
o=CiscoSystemsCCM-SIP 100429 4 IN IP4 10.135.191.12
s=SIP Call
t=0 0
m=audio 16384 RTP/AVP 0
c=IN IP4 239.1.1.1
a=X-cisco-media:mmoh+ConnSendOnly
a=ptime:20
a=recvonly
c=IN IP4 0.0.0.0
a=content:main
a=inactive
039429: Aug 28 09:09:03.453 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 103 INVITE
Content-Length: 0
039430: Aug 28 09:09:03.453 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6A5B5
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 294
v=0
o=CiscoSystemsSIP-GW-UserAgent 7259 1405 IN IP4 184.71.242.2
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
c=IN IP4 0.0.0.0
a=inactive
a=fmtp:101 0-16
a=ptime:20
039431: Aug 28 09:09:03.453 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6B1D6B
Min-SE:  1800
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 294
v=0
o=CiscoSystemsSIP-GW-UserAgent 7259 1406 IN IP4 184.71.242.2
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
c=IN IP4 0.0.0.0
a=sendonly
a=fmtp:101 0-16
a=ptime:20
039432: Aug 28 09:09:03.537 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6B1D6B;received=184.71.242.2
CSeq: 103 INVITE
Supported: replaces
Content-Length: 0
039433: Aug 28 09:09:03.537 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 INVITE
Supported: replaces
Content-Length: 310
v=0
o=root 1022 1025 IN IP4 208.43.85.75
s=session
b=CT:384
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=inactive
a=inactive
039434: Aug 28 09:09:03.545 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6C26BF
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 0
039435: Aug 28 09:09:03.545 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 279
v=0
o=CiscoSystemsSIP-GW-UserAgent 8203 269 IN IP4 172.18.0.1
s=SIP Call
c=IN IP4 172.18.0.1
t=0 0
c=IN IP4 239.1.1.1
a=inactive
a=ptime:20
c=IN IP4 172.18.0.1
a=fmtp:34 CIF=1
039436: Aug 28 09:09:03.549 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc20466fa4c5
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 0
039437: Aug 28 09:09:03.997 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc22648a2b14
CSeq: 104 INVITE
Max-Forwards: 70
Expires: 180
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Min-SE:  1800
Content-Length: 361
v=0
o=CiscoSystemsCCM-SIP 100429 5 IN IP4 10.135.191.12
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
a=ptime:20
a=inactive
a=content:main
a=inactive
039438: Aug 28 09:09:04.005 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 104 INVITE
Content-Length: 0
039439: Aug 28 09:09:04.005 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6D1B47
Date: Thu, 28 Aug 2014 15:09:04 GMT
Min-SE:  1800
CSeq: 104 INVITE
Max-Forwards: 70
Timestamp: 1409238544
Expires: 180
Content-Length: 294
v=0
o=CiscoSystemsSIP-GW-UserAgent 7259 1407 IN IP4 184.71.242.2
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
c=IN IP4 0.0.0.0
a=inactive
a=fmtp:101 0-16
a=ptime:20
039440: Aug 28 09:09:04.089 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6D1B47;received=184.71.242.2
CSeq: 104 INVITE
Supported: replaces
Content-Length: 0
039441: Aug 28 09:09:04.089 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 104 INVITE
Supported: replaces
Content-Length: 310
v=0
o=root 1022 1026 IN IP4 208.43.85.75
s=session
b=CT:384
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=inactive
a=inactive
039442: Aug 28 09:09:04.097 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6EC08
Max-Forwards: 70
CSeq: 104 ACK
Content-Length: 0
039443: Aug 28 09:09:04.097 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 104 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 280
v=0
s=SIP Call
c=IN IP4 172.18.0.1
t=0 0
c=IN IP4 172.18.0.1
a=inactive
a=ptime:20
c=IN IP4 172.18.0.1
a=fmtp:34 CIF=1
039444: Aug 28 09:09:04.101 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc234759966
Max-Forwards: 70
CSeq: 104 ACK
Content-Length: 0
039445: Aug 28 09:09:04.113 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:2000@172.18.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc24648aba28
Max-Forwards: 70
CSeq: 105 UPDATE
Min-SE:  1800
P-Asserted-Identity: "Anthony" <sip:270@10.135.191.12>
Remote-Party-ID: "Anthony" <sip:270@10.135.191.12>;party=calling;screen=yes;privacy=off
Content-Length: 0
039446: Aug 28 09:09:04.117 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 105 UPDATE
Contact: <sip:270@172.18.0.1:5060>
Require: timer
Supported: timer
Content-Length: 0
039447: Aug 28 09:09:04.125 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2665258271
CSeq: 106 INVITE
Max-Forwards: 70
Expires: 180
Min-SE:  1800
Content-Length: 0
039448: Aug 28 09:09:04.129 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 106 INVITE
Content-Length: 0
039449: Aug 28 09:09:04.129 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6F19D2
Min-SE:  1800
CSeq: 105 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
039450: Aug 28 09:09:04.213 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B6F19D2;received=184.71.242.2
CSeq: 105 INVITE
Supported: replaces
Content-Length: 0
039451: Aug 28 09:09:04.213 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 105 INVITE
Supported: replaces
Content-Length: 361
v=0
o=root 1022 1027 IN IP4 208.43.85.75
s=session
b=CT:384
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
a=sendrecv
039452: Aug 28 09:09:04.217 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 106 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 393
v=0
o=CiscoSystemsSIP-GW-UserAgent 8203 270 IN IP4 172.18.0.1
s=SIP Call
c=IN IP4 172.18.0.1
t=0 0
c=IN IP4 172.18.0.1
a=fmtp:101 0-16
a=ptime:20
m=video 18672 RTP/AVP 34 119
c=IN IP4 172.18.0.1
a=fmtp:34 CIF=1
039453: Aug 28 09:09:04.237 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:270@172.18.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2730d82576
Max-Forwards: 70
CSeq: 106 ACK
Content-Length: 371
v=0
o=CiscoSystemsCCM-SIP 100429 6 IN IP4 10.135.191.12
s=SIP Call
t=0 0
m=audio 4000 RTP/AVP 0
c=IN IP4 10.135.191.12
a=X-cisco-media:umoh
a=ptime:20
a=sendonly
c=IN IP4 0.0.0.0
a=content:main
a=inactive
039454: Aug 28 09:09:04.241 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B7068F
Max-Forwards: 70
CSeq: 105 ACK
Content-Length: 304
v=0
o=CiscoSystemsSIP-GW-UserAgent 7259 1408 IN IP4 184.71.242.2
s=SIP Call
t=0 0
a=sendonly
a=fmtp:101 0-16
a=ptime:20
039455: Aug 28 09:09:07.509 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:270@172.18.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc28659cd830
Date: Thu, 28 Aug 2014 15:09:07 GMT
CSeq: 107 INVITE
Max-Forwards: 70
Expires: 180
Min-SE:  1800
Content-Length: 347
v=0
o=CiscoSystemsCCM-SIP 100429 7 IN IP4 10.135.191.12
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
a=ptime:20
a=inactive
a=content:main
a=inactive
039456: Aug 28 09:09:07.517 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 107 INVITE
Content-Length: 0
039457: Aug 28 09:09:07.517 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B71E5E
Min-SE:  1800
CSeq: 106 INVITE
Max-Forwards: 70
Timestamp: 1409238547
Expires: 180
Content-Length: 294
v=0
o=CiscoSystemsSIP-GW-UserAgent 7259 1409 IN IP4 184.71.242.2
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
c=IN IP4 0.0.0.0
a=inactive
a=fmtp:101 0-16
a=ptime:20
039458: Aug 28 09:09:07.601 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B71E5E;received=184.71.242.2
CSeq: 106 INVITE
Supported: replaces
Content-Length: 0
039459: Aug 28 09:09:07.601 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 106 INVITE
Supported: replaces
Content-Length: 310
v=0
o=root 1022 1028 IN IP4 208.43.85.75
s=session
b=CT:384
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=inactive
a=inactive
039460: Aug 28 09:09:07.605 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B721B73
Max-Forwards: 70
CSeq: 106 ACK
Content-Length: 0
039461: Aug 28 09:09:07.605 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 107 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 280
v=0
s=SIP Call
c=IN IP4 172.18.0.1
t=0 0
c=IN IP4 172.18.0.1
a=inactive
a=ptime:20
c=IN IP4 172.18.0.1
a=fmtp:34 CIF=1
039462: Aug 28 09:09:07.609 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc292f69fb64
Max-Forwards: 70
CSeq: 107 ACK
Content-Length: 0
039463: Aug 28 09:09:07.617 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2a86fb648
CSeq: 108 INVITE
Max-Forwards: 70
Expires: 180
Min-SE:  1800
Contact: <sip:3000@10.135.191.12:5060>;video;audio
Content-Length: 0
039464: Aug 28 09:09:07.621 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 108 INVITE
Content-Length: 0
039465: Aug 28 09:09:07.621 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B73526
Min-SE:  1800
CSeq: 107 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
039466: Aug 28 09:09:07.701 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B73526;received=184.71.242.2
CSeq: 107 INVITE
Supported: replaces
Content-Length: 0
039467: Aug 28 09:09:07.705 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 107 INVITE
Supported: replaces
Content-Length: 361
v=0
o=root 1022 1029 IN IP4 208.43.85.75
s=session
b=CT:384
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
a=sendrecv
039468: Aug 28 09:09:07.709 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 108 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 393
v=0
o=CiscoSystemsSIP-GW-UserAgent 8203 271 IN IP4 172.18.0.1
s=SIP Call
c=IN IP4 172.18.0.1
t=0 0
c=IN IP4 172.18.0.1
a=fmtp:101 0-16
a=ptime:20
m=video 18674 RTP/AVP 34 119
c=IN IP4 172.18.0.1
a=fmtp:34 CIF=1
039469: Aug 28 09:09:07.721 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2b4dadf04c
Max-Forwards: 70
CSeq: 108 ACK
Content-Length: 405
v=0
o=CiscoSystemsCCM-SIP 100429 8 IN IP4 10.135.191.12
s=SIP Call
b=TIAS:64000
b=AS:64
t=0 0
m=audio 29928 RTP/AVP 0 101
c=IN IP4 10.135.191.54
a=fmtp:101 0-15
c=IN IP4 0.0.0.0
a=content:main
a=inactive
039470: Aug 28 09:09:07.729 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B7420AC
Max-Forwards: 70
CSeq: 107 ACK
Content-Length: 292
v=0
o=CiscoSystemsSIP-GW-UserAgent 7259 1410 IN IP4 184.71.242.2
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
039471: Aug 28 09:09:07.729 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:270@172.18.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2c12c97bd7
Max-Forwards: 70
CSeq: 109 UPDATE
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Min-SE:  1800
Contact: <sip:0b11a44f-86ee-41f9-ee7e-e8a942be2210@10.135.191.12:5060>
Content-Length: 0
039472: Aug 28 09:09:07.733 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 109 UPDATE
Require: timer
Supported: timer
Content-Length: 0
039473: Aug 28 09:09:16.049 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc2f4b354494
Date: Thu, 28 Aug 2014 15:09:15 GMT
CSeq: 110 INVITE
Max-Forwards: 70
Expires: 180
Min-SE:  1800
Content-Length: 393
v=0
o=CiscoSystemsCCM-SIP 100429 9 IN IP4 10.135.191.12
s=SIP Call
c=IN IP4 0.0.0.0
b=TIAS:64000
b=AS:64
t=0 0
a=inactive
a=fmtp:101 0-15
a=content:main
a=inactive
039474: Aug 28 09:09:16.057 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 28 Aug 2014 15:09:16 GMT
CSeq: 110 INVITE
Content-Length: 0
039475: Aug 28 09:09:16.057 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B751A02
Min-SE:  1800
CSeq: 108 INVITE
Max-Forwards: 70
Timestamp: 1409238556
Expires: 180
Content-Length: 294
v=0
o=CiscoSystemsSIP-GW-UserAgent 7259 1411 IN IP4 184.71.242.2
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
c=IN IP4 0.0.0.0
a=inactive
a=fmtp:101 0-16
a=ptime:20
039476: Aug 28 09:09:16.141 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B751A02;received=184.71.242.2
CSeq: 108 INVITE
Supported: replaces
Content-Length: 0
039477: Aug 28 09:09:16.141 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 108 INVITE
Supported: replaces
Content-Length: 310
v=0
o=root 1022 1030 IN IP4 208.43.85.75
s=session
b=CT:384
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=inactive
a=inactive
039478: Aug 28 09:09:16.149 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B7624B6
Max-Forwards: 70
CSeq: 108 ACK
Content-Length: 0
039479: Aug 28 09:09:16.149 MST: //6872/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 110 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 336
v=0
o=CiscoSystemsSIP-GW-UserAgent 8203 272 IN IP4 172.18.0.1
s=SIP Call
c=IN IP4 172.18.0.1
t=0 0
c=IN IP4 172.18.0.1
a=inactive
a=fmtp:101 0-16
a=ptime:20
c=IN IP4 172.18.0.1
a=fmtp:34 CIF=1
039480: Aug 28 09:09:16.153 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc30696ffa8d
Max-Forwards: 70
CSeq: 110 ACK
Content-Length: 0
039481: Aug 28 09:09:16.157 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:270@172.18.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.135.191.12:5060;branch=z9hG4bKc31527a26a6
Max-Forwards: 70
CSeq: 111 BYE
Reason: Q.850;cause=16
Content-Length: 0
039482: Aug 28 09:09:16.165 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:1111111111@208.43.85.75 SIP/2.0
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B772138
Max-Forwards: 70
CSeq: 109 BYE
P-RTP-Stat: PS=857,OS=137120,PR=620,OR=90776,PL=0,JI=0,LA=0,DU=18
Content-Length: 0
039483: Aug 28 09:09:16.165 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 111 BYE
P-RTP-Stat: PS=620,OS=90776,PR=857,OR=137120,PL=0,JI=0,LA=0,DU=18
Content-Length: 0
039484: Aug 28 09:09:16.249 MST: //6870/1164A17192EE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 184.71.242.2:5060;branch=z9hG4bK1B772138;received=184.71.242.2
CSeq: 109 BYE
Supported: replaces
Content-Length: 0
Looks like this was all
Looks like this was all caused by a DTMF mismatch between the provider and the CUCM SIP trunk...
Requiring MTP on the trunk fixed the issue.
The codec is G711ulaw
Relevant CUBE config:
voice service voip
 ip address trusted list
  ipv4 208.43.85.75 255.255.255.255
  ipv4 10.135.191.12 255.255.255.255
 mode border-element
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  registrar server expires max 1200 min 300
  early-offer forced
  midcall-signaling passthru
voice translation-rule 1
 rule 1 /^9/ //
voice translation-rule 2
 rule 1 /REDACTEDTENDIGITNUMBER/ /3000/
voice translation-profile INCOMING1
 translate called 2
voice translation-profile Strip9
 translate called 1
dial-peer voice 333 pots
 description Overhead PAging
 destination-pattern 3333
 port 0/0/0
 no sip-register
dial-peer voice 1000 voip
 description *** Outbound CUCM ***
 destination-pattern ....?
 session protocol sipv2
 session target ipv4:10.135.191.12
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 2000 voip
 description *** Inbound CUCM ***
 incoming called-number ....?
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 101 voip
 description *** Incoming Dial-Peer ***
 translation-profile incoming INCOMING1
 session target sip-server
 incoming called-number redactedtendigitnumber
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 1 voip
 description *** Outbound Dial-Peer ***
 translation-profile outgoing Strip9
 destination-pattern 9.+
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
sip-ua
 credentials username redacted password 7 redacted realm redacted
 authentication username redacted password 7 redacted
 registrar dns:sip1.ixica.com expires 60
 sip-server dns:sip1.ixica.com
537
