08-16-2010 09:14 AM - edited 03-16-2019 12:16 AM
I just upgraded a CUCMBE from version 7.1(2) to 7.1(3a). After the upgrade Unity Connection will not answers. Voicemail Pilot and all AA's will just ring and ring. I was trying to diagnose the issue and the Dialed Number Analyzer seems to show no issue - but does not really indicate where the call goes...
How can I determine if the call is getting to Unity Connection, and then how can I determine why Unity Connection is not picking the calls up.
VoiceMail Pilot - 699
Voicemail Ports - 600 - 615 (all registered)
Voicemail Hunt - 699
Line Group DN's - 600 - 615
The Analyzer shows the call going to the Hunt Group. So I thne tried analyzing the first number in the Voice Mail Ports....Here is the output.
Solved! Go to Solution.
08-16-2010 10:54 AM
Hi Heath,
Can you try resetting the Ports via UC admin> Telephony Integration> Port Group
Cheers!
Rob
08-16-2010 11:11 AM
Rob is right, Please reset your ports.
I found this from your logs
16:25:08 StatusDetails='' NeedRestartId='' VmsServerObjectId='' dtLastUpdated=2010-08-16 16:25:08]|
If this does not work I would suggest removing the ports and going through the
Unity Port Wizard again. Once you create them in CUCM, then create them in Unity.
Hope this helps, Please rate if so
Justin
08-16-2010 09:17 AM
Hi There,
Have you happened to check your services after the upgrade?
Also have you checked the upgrade logs for any errors?
Justin
08-16-2010 09:28 AM
Yes - all services are running - Except Database proxy....
Nothing in the logs (that I can find) was suspect.
I just finished recreating the VM ports - all are registered, but still no answer.
08-16-2010 09:32 AM
Hi Heath,
Can you please try dialing 699 and using DNA
In a properly configured integration you shouldn't be able
to dial to VM Ports (like 600) directly.
Cheers!
Rob
08-16-2010 09:37 AM
Hi Rob,
Dialing 699 - I get ring no answer (forever).... What did you mean DNA?
I just checked another CUCMBE system and I can dial all of the VM Ports directly.... That may mean it is not configured properly, but the system does work.
08-16-2010 09:38 AM
Sorry - DNA Dailed Number Anaylizer .... OOOPS.
Here is the output:
08-16-2010 09:41 AM
Are the voicemail ports registered?
08-16-2010 09:42 AM
Yes all ports are registered.
08-16-2010 09:38 AM
Try the port status monitor
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
08-16-2010 09:42 AM
Are the ports registered in CUCM? The status is coming up as Unknown.
Justin
08-16-2010 09:45 AM
All ports show registered to the BE.
Registered with CUCMBE-wyn
08-16-2010 09:44 AM
I just installed, but The add system option is greyed out.
08-16-2010 10:21 AM
OK - I got some logs out of Unity Connection - but what are they telling me?
08/16/2010 12:25:08.862 |27834,CUCMBE-wny-1-001,,Arbiter,13,Receive Miu notification PortStateChanged objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b'|
08/16/2010 12:25:08.862 |27834,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001 Miu state=[MediaPortObjectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b' Status=514=InService_InUse Extension='600' ConnectedTo='192.168.53.5:2000 (127.0.0.1)' dtStatusChanged=2010-08-16 16:25:08 StatusDetails='' NeedRestartId='' VmsServerObjectId='' dtLastUpdated=2010-08-16 16:25:08]|
08/16/2010 12:25:08.863 |27834,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001: state remains 512=InService (objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b')|
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,MiuIO,12,Enter CMiuMedia::MediaEventHandler |
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,MiuIO,12,CMiuMedia::MediaEventHandler-Disconnected|
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,MiuIO,12,Exit CMiuMedia::MediaEventHandler=0x00000000=S_OK|
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,Arbiter,13,Receive Miu notification PortStateChanged objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b'|
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001 Miu state=[MediaPortObjectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b' Status=513=InService_Idle Extension='600' ConnectedTo='192.168.53.5:2000 (127.0.0.1)' dtStatusChanged=2010-08-16 16:25:11 StatusDetails='' NeedRestartId='' VmsServerObjectId='' dtLastUpdated=2010-08-16 16:25:11]|
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001: state remains 512=InService (objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b')|
08/16/2010 12:25:14.159 |29514,CUCMBE-wny-1-001,,Arbiter,13,Receive Miu notification PortStateChanged objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b'|
08/16/2010 12:25:14.159 |29514,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001 Miu state=[MediaPortObjectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b' Status=514=InService_InUse Extension='600' ConnectedTo='192.168.53.5:2000 (127.0.0.1)' dtStatusChanged=2010-08-16 16:25:14 StatusDetails='' NeedRestartId='' VmsServerObjectId='' dtLastUpdated=2010-08-16 16:25:14]|
08/16/2010 12:25:14.159 |29514,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001: state remains 512=InService (objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b')|
08/16/2010 12:25:40.541 |27842,CUCMBE-wny-1-001,,MiuIO,12,Enter CMiuMedia::MediaEventHandler |
08/16/2010 12:25:40.542 |27842,CUCMBE-wny-1-001,,MiuIO,12,CMiuMedia::MediaEventHandler-Disconnected|
08/16/2010 12:25:40.542 |27842,CUCMBE-wny-1-001,,MiuIO,12,Exit CMiuMedia::MediaEventHandler=0x00000000=S_OK|
08/16/2010 12:25:40.542 |27842,CUCMBE-wny-1-001,,Arbiter,13,Receive Miu notification PortStateChanged objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b'|
08/16/2010 12:25:40.542 |27842,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001 Miu state=[MediaPortObjectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b' Status=513=InService_Idle Extension='600' ConnectedTo='192.168.53.5:2000 (127.0.0.1)' dtStatusChanged=2010-08-16 16:25:40 StatusDetails='' NeedRestartId='' VmsServerObjectId='' dtLastUpdated=2010-08-16 16:25:40]|
08/16/2010 12:25:40.542 |27842,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001: state remains 512=InService (objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b')|
08-16-2010 10:54 AM
Hi Heath,
Cheers!
Rob
08-16-2010 11:11 AM
Justin
