Unity Connect - ring no answer
HEATH FREEL
I just upgraded a CUCMBE from version 7.1(2) to 7.1(3a). After the upgrade Unity Connection will not answers. Voicemail Pilot and all AA's will just ring and ring. I was trying to diagnose the issue and the Dialed Number Analyzer seems to show no issue - but does not really indicate where the call goes...
How can I determine if the call is getting to Unity Connection, and then how can I determine why Unity Connection is not picking the calls up.
VoiceMail Pilot - 699
Voicemail Ports - 600 - 615 (all registered)
Voicemail Hunt  - 699
Line Group DN's - 600 - 615
The Analyzer shows the call going to the Hunt Group. So I thne tried analyzing the first number in the Voice Mail Ports....Here is the output.
  • Results  Summary
    • Calling Party Information
      • Calling Party = 1000
      • Partition =
      • Device CSS =
      • Line CSS =
      • AAR Group Name =
      • AAR CSS =
    • Dialed Digits = 600
    • Match Result = RouteThisPattern
    • Matched Pattern Information
      • Pattern = 600
      • Partition =
      • Time Schedule =
    • Called Party Number = 600
    • Time Zone =
    • Call Classification = OnNet
    • InterDigit Timeout = NO
    • Device Override = Disabled
    • Outside Dial Tone = NO
  • Call Flow
    • TranslationPattern :Pattern
      • Partition =
      • Positional Match List = 600
      • Calling Party Number = 1000
      • PreTransform Calling Party  Number =
      • PreTransform Called Party  Number =
      • Calling Party Transformations
        • External Phone Number  Mask = NO
        • Calling Party Mask =
        • Prefix =
        • CallingLineId  Presentation =
        • CallingName Presentation =
      • ConnectedParty Transformations
        • ConnectedLineId  Presentation =
        • ConnectedName  Presentation =
      • Called Party Transformations
        • Called Party Mask =
        • Discard Digits  Instruction =
        • Prefix =
        • Called Number =
  • Alternate Matches
    • Note: Information Not Available
2 Accepted Solutions
Rob Huffman
Hi Heath,
Can you try resetting the Ports via UC admin> Telephony Integration> Port Group
Cheers!
Rob
Rob is right,  Please reset your ports.
I found this from your logs
16:25:08 StatusDetails='' NeedRestartId='' VmsServerObjectId='' dtLastUpdated=2010-08-16 16:25:08]|
If this does not work I would suggest removing the ports and going through the
Unity Port Wizard again.  Once you create them in CUCM, then create them in Unity.
Hope this helps, Please rate if so
Justin
17 Replies 17
Justin Brenton
Level 4
Level 4
Hi There,
Have you happened to check your services after the upgrade?
Also have you checked the upgrade logs for any errors?
Justin
Yes - all services are running - Except Database proxy....
Nothing in the logs (that I can find) was suspect.
I just finished recreating the VM ports - all are registered, but still no answer.
Rob Huffman
Hi Heath,
Can you please try dialing 699 and using DNA
In a properly configured integration you shouldn't be able
to dial to VM Ports (like 600) directly.
Cheers!
Rob
Hi Rob,
Dialing 699 - I get ring no answer (forever).... What did you mean DNA?
I just checked another CUCMBE system and I can dial all of the VM Ports directly.... That may mean it is not configured properly, but the system does work.
Sorry - DNA Dailed Number Anaylizer .... OOOPS.
Here is the output:
  • Results  Summary
      • Partition =
      • Device CSS =
      • Line CSS =
      • AAR Group Name =
      • AAR CSS =
    • Dialed Digits = 699
      • Pattern = 699
      • Partition =
      • Time Schedule =
    • Called Party Number = 699
    • Time Zone =
    • End Device = Voicemail Hunt
  • Call Flow
      • Partition =
      • Positional Match List = 699
        • Prefix =
        • Prefix =
        • Called Number =
    • Hunt  Pilot :Pattern= 699
      • DialPlan =
      • Route  Filter
        • Filter Name =
        • Filter Clause =
      • Hunt Forward Settings
        • Forward Hunt No Answer
          • Use Personal Preferences =  No
          • Destination =
          • Calling Search Space =  CSS-Main
        • Forward Hunt Busy
          • Destination =
        • Maximum Hunt Timer =
      • PreTransform Calling Party  Number = 1000
      • PreTransform Called Party  Number = 699
        • Prefix =
        • CallingLineId  Presentation = Default
        • CallingName Presentation =  Default
        • ConnectedLineId  Presentation = Default
        • ConnectedName  Presentation = Default
        • Discard Digits  Instruction = None
        • Prefix =
        • Called Number = 699
    • Hunt  List :HuntListName= Voicemail Hunt
      • Line  Group :LineGroupName= Voicemail
        • Directory Number :DN= 600
          • Partition =
          • TypeCFACSSPolicy =
          • Device :Type= Cisco Voice Mail Port
            • Device Status = UnKnown
            • Device Name = CiscoUM1-VI1
            • Ignore Presentation  Indicators = Disabled
            • Logged Into Hunt Groups =  Enabled
            • Alerting Name =
            • Dual Mode = Disabled
            • Automated Alternate Routing  (AAR)
              • AAR Group Name =
              • AAR Calling Search Space =  CSS-Main
              • AAR VoiceMail Status =  Disabled
              • AAR Destination Mask =
              • AAR Prefix Digits =
        • Directory Number :DN= 601
          • Partition =
            • Device Name = CiscoUM1-VI2
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 602
          • Partition =
            • Device Name = CiscoUM1-VI3
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 603
          • Partition =
            • Device Name = CiscoUM1-VI4
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 604
          • Partition =
            • Device Name = CiscoUM1-VI5
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 605
          • Partition =
            • Device Name = CiscoUM1-VI6
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 606
          • Partition =
            • Device Name = CiscoUM1-VI7
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 607
          • Partition =
            • Device Name = CiscoUM1-VI8
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 608
          • Partition =
            • Device Name = CiscoUM1-VI9
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 609
          • Partition =
            • Device Name = CiscoUM1-VI10
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 610
          • Partition =
            • Device Name = CiscoUM1-VI11
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 611
          • Partition =
            • Device Name = CiscoUM1-VI12
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 612
          • Partition =
            • Device Name = CiscoUM1-VI13
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 613
          • Partition =
            • Device Name = CiscoUM1-VI14
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 614
          • Partition =
            • Device Name = CiscoUM1-VI15
            • Alerting Name =
              • AAR Group Name =
        • Directory Number :DN= 615
          • Partition =
            • Device Name = CiscoUM1-VI16
            • Alerting Name =
              • AAR Group Name =
  • Alternate Matches
Are the voicemail ports registered?
Yes all ports are registered.
Try the port status monitor
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Are the ports registered in CUCM? The status is coming up as Unknown.
Justin
All ports show registered to the BE.
Registered with CUCMBE-wyn
I just installed, but The add system option is greyed out.
OK - I got some logs out of Unity Connection - but what are they telling me?
08/16/2010 12:25:08.862 |27834,CUCMBE-wny-1-001,,Arbiter,13,Receive Miu notification PortStateChanged objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b'|
08/16/2010 12:25:08.862 |27834,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001 Miu state=[MediaPortObjectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b' Status=514=InService_InUse Extension='600' ConnectedTo='192.168.53.5:2000 (127.0.0.1)' dtStatusChanged=2010-08-16 16:25:08 StatusDetails='' NeedRestartId='' VmsServerObjectId='' dtLastUpdated=2010-08-16 16:25:08]|
08/16/2010 12:25:08.863 |27834,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001: state remains 512=InService (objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b')|
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,MiuIO,12,Enter CMiuMedia::MediaEventHandler |
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,MiuIO,12,CMiuMedia::MediaEventHandler-Disconnected|
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,MiuIO,12,Exit CMiuMedia::MediaEventHandler=0x00000000=S_OK|
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,Arbiter,13,Receive Miu notification PortStateChanged objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b'|
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001 Miu state=[MediaPortObjectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b' Status=513=InService_Idle Extension='600' ConnectedTo='192.168.53.5:2000 (127.0.0.1)' dtStatusChanged=2010-08-16 16:25:11 StatusDetails='' NeedRestartId='' VmsServerObjectId='' dtLastUpdated=2010-08-16 16:25:11]|
08/16/2010 12:25:11.807 |29515,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001: state remains 512=InService (objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b')|
08/16/2010 12:25:14.159 |29514,CUCMBE-wny-1-001,,Arbiter,13,Receive Miu notification PortStateChanged objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b'|
08/16/2010 12:25:14.159 |29514,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001 Miu state=[MediaPortObjectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b' Status=514=InService_InUse Extension='600' ConnectedTo='192.168.53.5:2000 (127.0.0.1)' dtStatusChanged=2010-08-16 16:25:14 StatusDetails='' NeedRestartId='' VmsServerObjectId='' dtLastUpdated=2010-08-16 16:25:14]|
08/16/2010 12:25:14.159 |29514,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001: state remains 512=InService (objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b')|
08/16/2010 12:25:40.541 |27842,CUCMBE-wny-1-001,,MiuIO,12,Enter CMiuMedia::MediaEventHandler |
08/16/2010 12:25:40.542 |27842,CUCMBE-wny-1-001,,MiuIO,12,CMiuMedia::MediaEventHandler-Disconnected|
08/16/2010 12:25:40.542 |27842,CUCMBE-wny-1-001,,MiuIO,12,Exit CMiuMedia::MediaEventHandler=0x00000000=S_OK|
08/16/2010 12:25:40.542 |27842,CUCMBE-wny-1-001,,Arbiter,13,Receive Miu notification PortStateChanged objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b'|
08/16/2010 12:25:40.542 |27842,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001 Miu state=[MediaPortObjectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b' Status=513=InService_Idle Extension='600' ConnectedTo='192.168.53.5:2000 (127.0.0.1)' dtStatusChanged=2010-08-16 16:25:40 StatusDetails='' NeedRestartId='' VmsServerObjectId='' dtLastUpdated=2010-08-16 16:25:40]|
08/16/2010 12:25:40.542 |27842,CUCMBE-wny-1-001,,Arbiter,13,Port=CUCMBE-wny-1-001: state remains 512=InService (objectId='4e89fdb4-d89f-4617-bf39-325cc6b0739b')|
Rob Huffman
Hi Heath,
Cheers!
Rob
Justin
